Assistance Required: Handling Metadata in Workflow for Specific Assets
  • December 19, 2024
  • 568 views
Hi Team,
Good day!
I have a question regarding workflow and its related metadata properties based on a scenario I encountered while working on a project.
Scenario Details:
  1. A new workflow job has been created, specific to one request.
  2. The job involves two assets:
    • Asset 1: Front (view of the front page).
    • Asset 2: Back (view of the back page).
  3. Metadata properties:
    • Count 5: Common metadata properties for both assets.
    • Count 3: Metadata properties with different values for each asset (e.g., color).
Challenge:
I understand the limitation where metadata properties in a workflow job are applied uniformly to all assets. When assets are sent to the "Assets" space in Bynder, the same metadata values are assigned to both assets, making it impossible to differentiate values for shared metadata properties within the same job.
Request:
I’d like to explore alternative approaches to meet this requirement, such as:
  1. Modifications or configurations within the current workflow to allow different metadata values for the same property per asset.
  2. Possible automation or scripting options to segregate metadata assignment post-upload.
  3. Any best practices or alternative workflows that might address this challenge effectively.
I’d appreciate your suggestions or insights to ensure that we can meet this project's requirements.
Looking forward to hearing your thoughts.
Thank you for your support!
Best regards,
Mandar Nimkar
Best answer by Mandar Nimkar
Hi ​@Ryanne Perry - Thanks for your inputs. However, the client does want automation for this within the process. I have come up with an out-of-the-box solution where I can capture different metadata properties in an external resource. Once assets have been pushed to the Assets space, I can use the update metadata properties API to update all assets with the metadata properties.
Thank you for your help and support. Much appreciated!🙂
Best regards,
Mandar Nimkar
View original
Hi ​@Mandar Nimkar. Thanks for taking the time to ask your question! A possible solution for this would be to configure the preset to export the assets to the Waiting Room. This means there is an additional step where the assets can be further enriched with metaproperties.
Best regards,
Mandar Nimkar
