March 2026 Product Release
Related products:2026
  • March 9, 2026
  • 142 views
CX User Community
Convert between Homepage and Landing Page layouts
You can now convert a Landing Page into a Homepage, and a Homepage into a Landing Page. This allows existing content to be repurposed without rebuilding the page from scratch. The conversion option is available to users with permission to edit both page types.
33878622701586
Learn more
Storybook embed
You can now embed Storybook stories directly into Guides and Landing Pages using a dedicated Storybook widget. By pasting a published Storybook URL into the widget, a live, interactive component preview is displayed within the page. This allows teams to reference design system components without recreating them manually.
33878650495250
Learn more
AI Writing Assistant
You can now use a Conversational AI assistant directly within the Text Widget in CX User Community Guides, Landing Pages, and Homepages. The assistant can generate new content, rewrite existing text, summarize, extend, or translate content based on prompts entered in the side panel. Generated text can be inserted or used to replace selected content within the widget. The AI assistant can be enabled from the portal settings page.
33878650498450
Learn more
DAM & CX Omnichannel
Derivative Metadata Extraction
You can now enable metadata inheritance for custom image derivatives and DAT files. When enabled, selected embedded metadata fields from the original asset are preserved in generated derivatives. This ensures that required fields remain embedded wherever derivatives are delivered.
Metadata is retained across API delivery, public links, downloads, and regenerated derivatives. It supports regeneration of existing assets, and inherited fields also apply to crop-generated derivatives.
33878622709394
Learn more
Enhanced filtering in Automations
Filtering options in the Automations tab have been expanded. You can now filter automations by Triggers, Actions, and by Any, All, or Specific conditions. This makes it easier to locate, review, and troubleshoot automations, especially in environments with many similar configurations.
33878622710674
Learn more
Studio
Brand Component Gallery
Studio now includes a Brand Component Gallery that replaces the previous text-based Preset Library with a visual component library. Users can save one or multiple design elements as reusable components and organize them into collections. Components are displayed with visual thumbnails, making them easier to find and preview before adding to a design. Components can be searched, renamed, described, moved between collections, and added directly to the canvas.
33878650502418
Learn more
Analytics
Access Rights Report
The Access Rights Report is now available in Analytics under Taxonomy. This report provides a self-serve overview of metadata option access configurations across the portal, including which profiles, groups, or users have specific permissions. Admins can review settings such as show or hide, add or edit, download, remove, and option disable.
Learn more
AI Search
Manual transcript edits persist in downloadable files
Manual edits made to Speech-to-Text transcripts now persist in downloadable transcript files. When a user updates transcript text in the editor, those changes are reflected in exported .TXT and .SRT files. The edited version is consistently used for download and downstream workflows.
33878622712978
Learn more
Custom Vocabulary for Speech-to-Text
You can now define a Custom Vocabulary to control how specific words are transcribed in Speech-to-Text. Admins can add single-word correction rules in Portal Settings to ensure brand names, product names, and domain-specific terms are transcribed correctly in video and audio uploads. Rules are applied automatically during transcription.
33878622714386
Learn more
Updated Select all behavior in Asset Bank (UI update)
The Select all option in Asset Bank has been updated for a more consistent interface. The button is now located next to the asset counter, and selecting more than 10,000 assets at once is no longer supported. The Select visible media and Select none options have been removed, while bulk actions and downloads continue to function within supported limits. Users can still select visible assets in the current view using keyboard shortcuts such as Cmd + A.
33878622715410
Learn more
Integrations
Bynder’s platform is open and connected with more than 145+ pre-built integrations and growing.  Check out our newest integrations:
Salesforce
You can now connect Bynder with Salesforce Data 360 to sync structured asset metadata, including tags and metaproperties, directly into Salesforce’s CDP. This makes governed content metadata addressable within segmentation and personalization workflows, enabling scalable, AI-driven content activation.
When used alongside DAM Connect, organizations can combine live, governed asset delivery with intelligent, metadata-powered personalization inside Salesforce.
Learn more
Echo3D
You can now connect Bynder with echo3D, a 3D digital asset management platform. This integration allows users to import 3D models, scans, and digital twins from Bynder into echo3D for further management. Users can search and filter assets using Bynder metadata, and updated asset versions in Bynder are reflected in echo3D. Within echo3D, users can view 3D files in a browser-based viewer, edit and optimize files, convert formats, track changes, and create shareable links for collaboration.
33878650504722
Learn more
FirstSpirit (neusta)
You can now connect Bynder with FirstSpirit. This integration allows content editors to search, select, and embed Bynder assets directly within the FirstSpirit content management interface. Assets remain stored and managed in Bynder, eliminating the need for manual downloads and uploads between systems.
33878622722450
Learn more
Metadata Importer & Exporter
You can now use the Metadata Importer and Exporter desktop applications to manage metadata in bulk. The Exporter allows you to export selected metadata from Bynder to CSV or Excel using configurable filters for properties, tags, and dates. Exported files can include direct asset links and saved configurations for recurring workflows. The Importer allows you to update metadata in bulk by uploading a structured CSV file. Users can choose which fields to update or overwrite before applying changes.
33878650506002
Learn more
Monday Service
You can now connect Bynder with monday service to manage brand support requests. Incoming requests from email, Slack, Teams, or web portals are centralized in monday service and linked to Bynder for asset retrieval. The integration connects ticket workflows with Bynder search and metadata. AI analyzes each request and retrieves relevant assets from Bynder based on metadata and content. Requests that require review can be routed to team members with full context.
33878650506514
Learn more
Pixelz
You can now connect Bynder with Pixelz to receive finished images directly in your DAM. Once enabled, approved images are automatically delivered from Pixelz to Bynder. This removes the need to manually download and upload files between systems. Assets are stored and managed in Bynder according to your existing DAM structure and workflows.
33878650507538
Learn more
Frame.io (i-Hub)
You can now connect Bynder with Frame.io via i-Hub to send approved video assets directly to Bynder using a “Send to Bynder” action. Assets are transferred without manual download and re-upload, and metadata mapping can be configured in i-Hub to apply Frame.io metadata on import. Frame.io supports in-progress collaboration, while Bynder manages final approved assets.
vendula onisko
@Ryanne Perry Thanks for sharing these updates 🙏 I always look forward to them! 🙂
We’re currently rolling out Studio, so I’m particularly excited about the Studio Brand Component Gallery.
  • March 16, 2026
The Analytics access rights report would be so handy. I am not seeing it as an option in my menu though, is it something you need an upgraded analytics package for? ​@Ryanne Perry
  • April 9, 2026
Hi ​@molly.caple - yes the Access Rights Report is part of our Standard or Advanced Analytics packages. Please get in touch with your customer success contact if you’d like to upgrade.
