URL Generator Chrome Extension
  • Dec 11, 2023 11:53 PM UTC
  • Jul 9, 2025 4:20 PM UTC
  • 31 replies
  • 2452 views
Show first post
I’ve tried using the Link Builder; however, it doesn’t seem to work if your metaproperty option is two words. e.g., Metaproperty: Document, Option: Sales Sheet.
Any suggestions?
  • May 27, 2025 11:57 PM UTC
Really wish this extension worked again. I used to use it everyday. Can anyone create a new one? This one just does not work anymore. Links come up blank!
  • Jun 20, 2025 10:59 AM UTC
We've built a Link Builder website that allows customers to generate direct links to pre-filtered sections of the Asset Bank—eliminating the need to navigate through multiple Excel sheets.
Here’s the custom link: https://dam.bynder.com/by/link-builder
And if you'd like to explore the backend: GitHub link
This is a fantastic tool, thanks for sharing! I also was sad that the BURLIE link stopped working.
I also agree it would be great to have this functionality built directly into the DAM :)
  • Jul 9, 2025 4:21 PM UTC
​@filmester I understand it’s frustrating to see the original solution not working :(
The Bynder team has worked to create a solution that works similarly, I hope it helps you. https://chromewebstore.google.com/detail/bynder-filter-url-generat/kmjbefjcflbegkomplljokogkjnfifhm?pli=1
  • Jul 9, 2025 6:49 PM UTC
​@Ryanne Perry I just installed it but keep getting the following error even though I am in our Bynder portal:
⚠️ This extension only works on Bynder portal pages.
Navigate to your Bynder portal to use this extension.
  • Jul 10, 2025 2:31 PM UTC
Thanks for flagging ​@filmester! I am happy to report that a fix is in progress for this and should be implemented within the next few days!
