URL Generator Chrome Extension
  • December 11, 2023
  • 31 replies
  • 1227 views
Hi. I made a simple Chrome extension to quickly generate URLs for metaproperty filter results that can be shared with team members. Hopefully this can helpful for others:
https://chromewebstore.google.com/detail/burlie-bynder-url-initiat/pajbcklakacmobandenpkpdjldhfgjac?hl=en
It’s rough around the edges right now. Consider it a beta. @Brynlee Emery
Overview
Generate sharable URLs for your Bynder DAM metaproperty filters in one click.
1.) Filter metaproperties from you Bynder DAM.
2.) Click the BURLIE icon to copy/paste the sharable URL.
Please note: These links only work for users with access to your DAM. These links do not create or replace Bynder collections.
**UPDATE by ​@Ryanne Perry it appears this solution is no longer active. We have seen so much interest in this solution that Bynder has created something similar that you can find here https://chromewebstore.google.com/detail/bynder-filter-url-generat/kmjbefjcflbegkomplljokogkjnfifhm?pli=1
Claire
  • Byndie
  • December 12, 2023
Everyone in onboarding is ecstatic about this extension, I’m sure Brynlee told you but I want to say so myself
  • December 12, 2023
Great to see you in the Community @juanm! Thank you for your amazing contribution ⭐ I have shared this as a resource to other teams as well.
  • December 12, 2023
That’s great to hear! Thanks!
Please let me know if you find any bugs or if there are any features people would like to see and I’ll try my best to implement them (time permitting).
  • December 14, 2023
A new version (v0.2) should be live soon.
v0.2: Added support for tags and search terms.
v0.3: Will have the option to add/remove quick links to modules and asset statuses in the popup. Plus some aesthetic changes.
Anything else people would like to see?
Claire
  • Byndie
  • December 14, 2023
search terms is what I was going to ask for. when you’re doing the limited/archive asset statuses remember to do isactive too!
  • December 17, 2023
Version 0.3 is live. It has some style changes, quick links, and a few options.
It was difficult to test all the quick links in the test portal, but I based them on the Bynder supplied quick links so I trusted they were accurate.
Brynlee Emery
So cool, Juan! These are awesome improvements
Claire
  • Byndie
  • December 21, 2023
Love these, love the update
  • December 21, 2023
If I added some (light) internationalization in a future version, what languages would you suggest, @Brynlee Emery? Or is English the majority of the customer base?
  • December 24, 2023
A new version (v0.5.0) should be live soon. It includes a new feature to quickly add the results link to the user’s homepage. It prefills the link input and news type.
I hope it adds convenience for some.
Fantastic tool :)
It really should be an integrated part of the platform!
LPGBC
  • March 22, 2024
@juanm I love this extension and definitely adds to the Bynder experience.
However, I’ve come across something weird, at least for my portal. It only works in my sandbox environment, not production. Even with the main portal as the Bynder Base URL, Burlie only works in the sandbox.
Has anyone else come across this issue or know a workaround that might allow us to use this in our main portal? Thanks!
  • March 22, 2024
@LPGBC That’s odd. I have one idea why this may be but I’ll need to reach out to Bynder first.
Can you send me a Private Message with your asset bank URL?
I hope to have an in-app feedback feature in the near future to make reporting and fixing bugs easier. Thanks for bringing this to my attention!
I’ll follow up here when I have a fix.
Claire
  • Byndie
  • March 27, 2024
@juanm Onboarding has noticed that it would be best to put ?resetsearch= in the parameters of URLs that BURLIE is generating for homepage filter links, this way when you click the link it clears any other filters you had applied previously (otherwise it concatenates filters and you get no results). Is this possible to add?
https://fruit.bynder.com/media/?resetsearch=
  • March 29, 2024
@Claire Yeah can do. I’ll get that live this weekend.
Andrew Edwards
@juanm This is extension is great, thank you. I’ll share with the wider team and send any feedback your way. 😎😁
  • May 13, 2024
Thanks @Andrew Edwards. Sounds good.
vendula onisko
I just discovered this tool, and it’s amazing! I’m thrilled to share it with our DigiHub users. 😊
It’s such a great resource, and I think it would be really beneficial to include it in the onboarding process—it would save so much time!
  • March 25, 2025
HI  - Is anyone having problems with BURLIE today?  Ours isnt showing the URL?  ​@juanm
vendula onisko
Same for me, it shows me “no filters found”.  Do you have any ideas, what is wrong?
  • April 9, 2025
Same here.  I started seeing it on Monday
  • April 9, 2025
Ah! i’m also experiencing the same issue with the extension. I love it and use it frequently - has anyone had any luck with it? or ideas for a workaround? Thanks!
  • April 9, 2025
Thanks all for flagging! I am looking into this further to see what insights or developments I can offer.
  • April 24, 2025
While we haven’t been able to get in touch with Juan just yet, I wanted to share an in-house workaround that may be helpful in the meantime.
We've built a Link Builder website that allows customers to generate direct links to pre-filtered sections of the Asset Bank—eliminating the need to navigate through multiple Excel sheets.
Here’s the custom link: https://dam.bynder.com/by/link-builder
And if you'd like to explore the backend: GitHub link
vendula onisko
Hi ​@Ryanne Perry
This is much better options than using an Excel sheet—thanks so much! It would be fantastic to have that functionality built directly into the DAM. Maybe it’s something we can look forward to in the future? 😇
