Hi everyone, I have been working on a custom automation pipeline to batch upload and tag creative UI assets directly into our Bynder portal via the API, but I keep encountering unpredictable execution stalls during mid-batch transfers. While standard media files process without any hitch, larger batches with nested custom metadata frequently hang or trigger unexpected timeout responses.
Our team runs these tasks across multiple dev machines, and we suspect that environmental differences and script compatibility between our local execution environments and the endpoint listeners might be causing these dropped sessions. Has anyone encountered similar runtime roadblocks when handling automated asset workflows, and are there particular environment configurations or payload pacing strategies you recommend to ensure smooth execution?
