Studio: Direct link to template categories
  • February 27, 2024
  • 449 views
andy
Is there a way to send people directly to a digital brand template or a category of digital brand templates? And can we make it so light users can see the categories to choose from without having to hit create new? Most of our users don’t understand there are so many to choose from and have to be instructed to click create new, it’s not intuitive. And it would be more enticing if they could see all the categories to choose from. Thanks!
Cory Nesselbush
Hi Andy, the answer is yes to both!
First things first, an easy way to open the New design modal is to append this to your Bynder URL:
.../studio/#/designs?create=true
e.g. https://dam.bynder.com/studio/#/designs?create=true
Your creators/light users will see a menu of the categories and templates shared with them, but designers and admins will see the full set of options, including the ability to share. This works great from the homepage to quickly get users to select from the templates they can create from.
From that modal find the category or template you’d like to link directly to, click the three dots meatballs menu, and select Share. In the bottom left corner you’ll see a handy Copy link button which should be exactly what you’re looking for.
You’ll notice the URL structure starts the same as above with the following parameters added where CCCCC is category ID and TTTTT is template ID:
.../studio/#/designs?create=true&page=category_details&categoryId=CCCCC
.../studio/#/designs?create=true&template=TTTTT&page=template_preview
It can be quite useful to link directly to categories and/or templates from Guidelines.
Hope that helps, and thanks for contributing to the Community!
andy
  • March 1, 2024
Oh wow, that is helpful to know it exists, thanks! Would still love the homepage for digital templates to show all the categories if that’s an option that could be built in the future, but this helps for sending people direct links. Thanks!
