Shortened urls
  • May 20, 2024
  • 439 views
We have trouble with the long url that is generated using the transfer/share file feature. It would be great if these could be truncated. Thank you.
  • May 20, 2024
Great to see you in the Community @dmcnaughton! Thank you for taking the time to share this with us. I will create a product request on your behalf.
In case it’s helpful to you, you might consider a tool like bitly to create shorter links. Though this would be manual.
  • May 20, 2024
I may have misunderstood, but I thought that using a 3rd party tool was not an option.
Can I shorten or trunkate the long url generated when using the transfer function on our DAM? (like with Bitly, etc)”
reply: The ability to shorten or truncate the long url generated when using the transfer function is
not possible within Bynder.
Claire
  • Byndie
  • May 20, 2024
Right it’s not built in to Bynder but you could get the transfer link from Bynder and pop it in a third party url shortener to get a shorter one
  • May 21, 2024
Hi @dmcnaughton I heard back from Product that this request is on our Roadmap.  You are welcome to follow the status and vote on here.
