Question
Select related assets
  • Mar 25, 2026 1:03 PM UTC
  • 5 replies
  • 615 views
Caroline
Request regarding related assets.
We work quite a lot with related assets, and several users have asked about the option to select all related assets to either download, share or create a collection. Is this something you have looked into - or plan to look into?
/Caroline
  • Apr 1, 2026 4:01 PM UTC
This is a great idea! I’d also like to be able to select the asset in view and the related assets and perform bulk metadata edit. Another helpful feature would be an ability to browse/review large previews of related assets in a modal window or new tab.
​@Caroline that is a great use case. If you can please submit your request here so it can be flagged with our product team. Thank you for bringing this to our attention!
  • Apr 22, 2026 4:35 PM UTC
Is there a way to add or delete one or more asset to a group of related assets?
brett.mcgaffigan
​@Nadine - Yes, you can add or remove related assets. Check out this article for more information on how to do so!
Did this answer your question, or were you looking to accomplish something else?
  • Apr 24, 2026 7:40 PM UTC
​@brett.mcgaffigan I am looking to accomplish something else.
  • If I have three assets that are related, how can I add a fourth asset so that it becomes related to all three, and when you select any one asset, you see the other three listed as related assets? When I add a related asset, it only connects to one of the three. I may be doing something wrong.
  • I also want to make sure the system does not override the original related assets setup.
