Integrating Bynder compact view with React V18.0.2
  • July 29, 2025
  • 256 views
Hi Team,
I am trying to integrate, bynder compact view npm package (@bynder/compact-view) in my react application. The version of react used is v18.0.2. I followed the same approach as mentioned in the page: https://www.npmjs.com/package/@bynder/compact-view. I did not get any errors but the component didn't show up inside the application, while I was able to see the code for compact view loaded in the developer tools. I tried to change the CSS properties, still didn't work.
However, the same code worked when I used it with react v17.0.2
  • July 30, 2025
Great to see you in the Community ​@Keziyah! Thank you for taking the time to ask your question. In order to assist you can you please provide more details? Specifically, it would be helpful to see screenshots, videos, any error messages or code issues, how UCV is set up in your codebase, and which version of UCV you’re using.
