High Volume Asset Uploading and Tagging
  • Nov 23, 2026 3:33 AM UTC
  • 1 view
Dylan W
Hello community,
I’m keen to get your thoughts on regular high volume asset upload and tagging pipelines. If you do this kind of thing, what solutions have you tried, what works best for you etc.?
When our eCom asset work stream was established I had access to tech squads who built a process using the API, which has been great, but getting support to change and keep up with our DAM as it evolves has been impossible, and I’m looking for something I can do at the same scale but have more control over as things change and evolve.
Mass Uploader is my best option to date and it’s great for batches of 100’s of assets, however, not so much for 1000’s+.
The New Workspace will be limited in the same way as Mass Uploader.
I’ve tried the Dropbox integration, its very close, but only has basic tagging control and a file’s embedded metadata tags are being ignored 😞
What other opportunities am I missing?
Thanks
Dyl
