Compact View Error - not able to pick asset
  • December 9, 2025
  • 399 views
Team,
We attempted to adopt Bynder Compact View v5 to unblock our asset selector and align with our React 19 upgrade. The NPM/Yarn packages appear broken (
) or incompatible with React 19 (
), and even the official demo and the script served from Bynder’s CDN produce failure. Specifically, the UI displays an “empty” label in the select box next to the “Add asset” button, and the “Add asset” button itself is not clickable.
We were unable to locate links to previous v5 releases to roll back to a known-good build. This leaves us without a viable integration path and is currently blocking our upgrade plan.
What we tried
  • Verified behavior against Bynder’s official demo and the script provided on their site (https://ucv.bynder.com/5.0.5/modules/compactview/bynder-compactview-5-latest.js).
  • Observed consistent UI failure: the selector shows “empty,” and the “Add asset” action cannot be triggered.
  • Searched for prior versions or pinned builds of v5 (no obvious way to access earlier point releases).
  • Tried to use npm package v3-v4
Impact
  • Our application upgrade is blocked until we have a working Bynder Compact View integration that functions with React 19, or a stable fallback we can pin to.
  • Delivery timelines are at risk because we cannot proceed with the asset selection flow in environments that depend on v5.
  • Without access to previous, working v5 builds, we lack a short-term rollback option, increasing the likelihood of continued delays.
What we need from the vendor
  • A working, React 19–compatible package for Bynder Compact View v5 published to NPM/Yarn, or
  • A stable, compiled CDN build for a known-good v5 release, with accessible versioned links so we can pin reliably, and
  • Clarity on a release plan and timeline for resolving the current breakage, plus a brief changelog so we can assess risk.
Why this matters now We are at the point where this integration is a critical path dependency. The absence of a functioning package and the lack of accessible, versioned prior builds leave us with no immediate workaround. We need a concrete path forward (either a fixed current version or a reliable previous version we can pin) to keep our upgrade on track and avoid further delays.
Please refer to this issue: https://nextjs.org/blog/CVE-2025-66478
  • December 9, 2025
Hi ​@mosoket992 can you confirm the Account where this issue is occurring? I want to make sure I have everything needed to pass along to Support for deeper troubleshooting.
  • December 15, 2025
In the browser’s console I can see at least 3 CORS errors on v5 compact view.
Access to XMLHttpRequest at 'https://MYCOMPANY.webdamdb.com/api/v4/smartfilters' from origin 'https://XXXX.azurewebsites.net' has been blocked by CORS policy: Response to preflight request doesn't pass access control check: No 'Access-Control-Allow-Origin' header is present on the requested resource
Access to XMLHttpRequest at 'https://MYCOMPANY.webdamdb.com/api/v4/media?total=false&count=true&limit=0&type=image' from origin 'https://XXXXX.azurewebsites.net' has been blocked by CORS policy: Response to preflight request doesn't pass access control check: No 'Access-Control-Allow-Origin' header is present on the requested resource.
Access to fetch at 'https://MYCOMPANY.webdamdb.com/v7/api/graphql' from origin 'https://XXXXXX.azurewebsites.net' has been blocked by CORS policy: Response to preflight request doesn't pass access control check: No 'Access-Control-Allow-Origin' header is present on the requested resource.
  • January 17, 2026
Hi,
It sounds like the integration challenges with Bynder Compact View v5 and React 19 are really blocking your workflow. One workaround some developers use for testing or managing complex UI components is leveraging advanced configuration tools. While this won’t directly fix Bynder, using similar approaches can sometimes help identify compatibility conflicts or streamline setup before deploying to production.
Hopefully, this gives some ideas while waiting for a stable v5 release or an official rollback build.
