Bynder BI Analytics API as a Web API source for Power BI Reporting
  • January 21, 2024
  • 250 views
We are working on a requirement to do customized reports using Power BI using the Bynder BI Analytics API.
Have anyone done this? and can you share the steps on how you were able to integrate Power BI to the Bynder APIs.
  • October 20, 2025
Thank you for your patience! It looks like this post slipped through the cracks. Have you had any luck setting up customized reports for this? I also came across this knowledge base article that explains how to use the API to get more granular insights.
