Better organization in Studio
  • May 1, 2026
  • 306 views
andy
Is it just me or would having more capability to organize how your template categories show up in the module be helpful? I find it super frustrating they only list by order they are created, they should at least be able to be sorted alpha so a user can find what they need more readily. Currently the templates are not listed in a way where options related to each other are near each other and there’s no simple way for people to find things since it is random. Would love to be able to order them manually and even create separation with an additional designation of categories like this:
EVENT TEMPLATES
category
category
category
HIRING TEMPLATES
category
category
category
PRINT TEMPLATES
category
category
category
Thanks!
  • May 11, 2026
We have issues with this too and your suggested improvements would be perfect.
brett.mcgaffigan
Thank you both so much for the feedback! Please make sure that you’re also submitting this as an idea on our roadmap page as well. This ensures that it’s captured in our product team’s internal system for them to review.
vendula onisko
Hi ​@andy ,
It’s not just you - we actually discussed this during our onboarding as well. I had to come up with a solution for our team, and what works for us (for now) is keeping a list of projects in a shared sheet that’s accessible directly from the Bynder homepage. Each team can then filter for their specific projects and access the related template links easily.
It’s definitely not an ideal setup, but it does the job for now. Hopefully Bynder will introduce the categories and improvements you mentioned in the future :)
