Hi. I made a simple Chrome extension to quickly generate URLs for metaproperty filter results that can be shared with team members. Hopefully this can helpful for others:
https://chromewebstore.google.com/detail/burlie-bynder-url-initiat/pajbcklakacmobandenpkpdjldhfgjac?hl=en
It’s rough around the edges right now. Consider it a beta. @Brynlee Emery
Overview
Generate sharable URLs for your Bynder DAM metaproperty filters in one click.
1.) Filter metaproperties from you Bynder DAM.
2.) Click the BURLIE icon to copy/paste the sharable URL.
Please note: These links only work for users with access to your DAM. These links do not create or replace Bynder collections.
Everyone in onboarding is ecstatic about this extension, I’m sure Brynlee told you but I want to say so myself
Great to see you in the Community @juanm! Thank you for your amazing contribution
I have shared this as a resource to other teams as well.
That’s great to hear! Thanks!
Please let me know if you find any bugs or if there are any features people would like to see and I’ll try my best to implement them (time permitting).
A new version (v0.2) should be live soon.
v0.2: Added support for tags and search terms.
v0.3: Will have the option to add/remove quick links to modules and asset statuses in the popup. Plus some aesthetic changes.
Anything else people would like to see?
search terms is what I was going to ask for. when you’re doing the limited/archive asset statuses remember to do isactive too!
Version 0.3 is live. It has some style changes, quick links, and a few options.
It was difficult to test all the quick links in the test portal, but I based them on the Bynder supplied quick links so I trusted they were accurate.
So cool, Juan! These are awesome improvements
Love these, love the update
If I added some (light) internationalization in a future version, what languages would you suggest, @Brynlee Emery? Or is English the majority of the customer base?
A new version (v0.5.0) should be live soon. It includes a new feature to quickly add the results link to the user’s homepage. It prefills the link input and news type.
I hope it adds convenience for some.
Fantastic tool :)
It really should be an integrated part of the platform!
@juanm I love this extension and definitely adds to the Bynder experience.
However, I’ve come across something weird, at least for my portal. It only works in my sandbox environment, not production. Even with the main portal as the Bynder Base URL, Burlie only works in the sandbox.
Has anyone else come across this issue or know a workaround that might allow us to use this in our main portal? Thanks!
@LPGBC That’s odd. I have one idea why this may be but I’ll need to reach out to Bynder first.
Can you send me a Private Message with your asset bank URL?
I hope to have an in-app feedback feature in the near future to make reporting and fixing bugs easier. Thanks for bringing this to my attention!
I’ll follow up here when I have a fix.
@juanm Onboarding has noticed that it would be best to put ?resetsearch= in the parameters of URLs that BURLIE is generating for homepage filter links, this way when you click the link it clears any other filters you had applied previously (otherwise it concatenates filters and you get no results). Is this possible to add?
https://fruit.bynder.com/media/?resetsearch=
@Claire Yeah can do. I’ll get that live this weekend.
@juanm This is extension is great, thank you. I’ll share with the wider team and send any feedback your way.
Thanks @Andrew Edwards. Sounds good.
I just discovered this tool, and it’s amazing! I’m thrilled to share it with our DigiHub users.
It’s such a great resource, and I think it would be really beneficial to include it in the onboarding process—it would save so much time!
HI - Is anyone having problems with BURLIE today? Ours isnt showing the URL? @juanm
