How to output retina images (2x) using DAT?
  • Mar 29, 2024 1:15 PM UTC
  • 319 views
We need Bynder to have features to handle responsive image loading: anything like Device Pixel Ratio dpr (https://docs.imgix.com/apis/rendering/pixel-density/dpr)
or https://docs.imgix.com/tutorials/responsive-images-srcset-imgix
using dynamic SRC sets. It would suck if we had to manually calculate doubling pixels for every one of our images because we want them to be 2x, not 1x.
Can you help?
Dylan W
  • Creator
  • Oct 7, 2025 9:43 PM UTC
Not sure if this helps you but I’ve noticed our implementation’s source set contains a different transform URL for each size, see example below, only problem is if the original image resolution is lower than any of those formats then the output is fixed to the lowest resolution.
srcset="https://assets.kmart.com.au/transform/83759511-ab34-4111-998a-d45e4edf2a92/43620890-1?io=transform:fit,width:640,height:640&quality=90 640w, https://assets.kmart.com.au/transform/83759511-ab34-4111-998a-d45e4edf2a92/43620890-1?io=transform:fit,width:750,height:750&quality=90 750w, https://assets.kmart.com.au/transform/83759511-ab34-4111-998a-d45e4edf2a92/43620890-1?io=transform:fit,width:828,height:828&quality=90 828w, https://assets.kmart.com.au/transform/83759511-ab34-4111-998a-d45e4edf2a92/43620890-1?io=transform:fit,width:1080,height:1080&quality=90 1080w, https://assets.kmart.com.au/transform/83759511-ab34-4111-998a-d45e4edf2a92/43620890-1?io=transform:fit,width:1200,height:1200&quality=90 1200w, https://assets.kmart.com.au/transform/83759511-ab34-4111-998a-d45e4edf2a92/43620890-1?io=transform:fit,width:1920,height:1920&quality=90 1920w, https://assets.kmart.com.au/transform/83759511-ab34-4111-998a-d45e4edf2a92/43620890-1?io=transform:fit,width:2048,height:2048&quality=90 2048w"
