Duplicate Finder Issue
  • June 24, 2024
  • 357 views
We are having an issue when very similar files are showing up in our duplicate finder. We have many images with only a slight difference in them. I wish there was an option to ignore when file names are different. Here are lifestyle images with different file names that showed up as duplicates
  If we want to keep both I guess they will forever show up on our duplicate finder list. Which after a while makes it time consuming to manage.
Is anyone else having an issue with this, and does anyone have a work around?
My apologies if this has been brought up before.
Thanks,
Glenn Bassett
  • June 24, 2024
Hi @Glenn Bassett. Thank you for taking the time to ask your question. This is indeed a feature request. I will submit this as a request on your behalf.
KevinMurphy
  • DAM Star
  • June 26, 2024
@Glenn Bassett , we only see duplicates upon upload with our version of Bynder. So after the initial upload and seeing the orange Duplicate tag, we can verify quickly, then approve / deny. After that point, we only get the duplicate tag if that image is uploaded again.
We have the updated Duplicate Finder with the AI Search package, so I can’t speak for the other version of Duplicate Finder.
