Bynder-Sprinklr integration
  • October 12, 2023
  • 241 views
We learned that Bynder has pre-built integration with Sprinklr. Can we learn how long it would normally take to finalize this kind of pre-built integration?
Reyhan
Best answer by Bas van Reeuwijk
Hi Runsalan,
The implementation of the Bynder integration is planned to take around 12 weeks across Plan, Build, Educate & Empower phases. But since the integration is built and supported by Sprinklr it would be best to contact them directly.
Kind Regards,
Bas van Reeuwijk
Bas van Reeuwijk
Hi Runsalan,
Kind Regards,
Bas van Reeuwijk
