Alpha autocomplete vs closest match to what I am actually typing is super annoying!
  • November 21, 2023
  • 442 views
andy
It is super frustrating how autocomplete doesn’t finish what I am typing but instead searches for the text I am typing and goes for the alpha-order tag that has those letters in it vs what is closest to what I am actually typing. For example, if I type “Survey” it will autocomplete to “Alumni Survey” since “A” is alpha first. This isn’t helpful, if I wanted to tag Alumni Survey I would have typed Alumni first. Often I hit return to autocomplete or accidentally click on the first option when I don’t mean to. It’s very rare that I wouldn’t get the exact word right, and in those instances I would rather it list those options last that match the word but don’t start like how I typed. Another example, when I type “Line”, “Application Deadline, Apply Online, License Pipeline” all come up before “Line” itself. See attached images.
grace.sherman
Hi Andy - thanks for taking the time to share this feedback! I’ve passed along to our Product team.
Klaas de Bont
hi @andy, thank you for this feedback. It’s the first time i’m hearing about this, but you’ve made your point quite clear. I can see how this current behavior is not particularly helpful.
You focused your screenshots on Tags in the Upload-screen, yet there’s also a metaproperty-type autocomplete which is actually hindered from the same behavior.
Would you envision a solution as in this quick & dirty mockup below?
Thinking about it a little longer, there could be 3 layers for showing the text matching the input:
When typing Tree:
1/ show exact match  (Tree)
2/ show partial matches (Palm Tree)
3/ show close matches (Street, Street Art)
andy
  • November 28, 2023
Thanks @Klaas de Bont that would be super helpful, the way I imagine it would be like this:
As I type “Tree” it would autocomplete to the closest match to what I am typing so it might look like this:
Typed: Tre
Results would be alpha close to what I am typing preference to how I start it, so it must start with Tre to show up first:
Treat
Tree
Trend
Then close matches
Once I type the second “e” to make it “Tree” it would change to:
Tree
then close matches as you have above
Does that make sense?
