Question
Naming Convention in Collections
  • 28 August 2023
  • 125 views
Is there any best practices to follow when naming collections? Should users across an organization use the same naming conventions?
Userlevel 4
Hey there! I think this depends on how you’re using collections in your organization. Can you give me an example? (i.e. are they for sharing assets with agencies, are they for internal shortcut access to a particular group of assets, are they for personal reference...)
@Brynlee Emery We would be using Collections for all of the scenarios you mentioned.
Userlevel 4
Bumping the idea for sub collections!
Reply
