Is there any best practices to follow when naming collections? Should users across an organization use the same naming conventions?
Hey there! I think this depends on how you’re using collections in your organization. Can you give me an example? (i.e. are they for sharing assets with agencies, are they for internal shortcut access to a particular group of assets, are they for personal reference...)
Reply
Login to the community
Bynder Employee SSO
Bynder Employee login hereor
Enter your username or e-mail address. We'll send you an e-mail with instructions to reset your password.
